Page 37 sur 44
Posté : 15 janv. 2017, 23:52
par Airspeed
germandrag a écrit :Yes exactly, 48 or 50 mm
Merci white lady !
Yes, as in the picture: 4 ones up front, but they are unmachined: they are 55mm and overlength. Hope thats clear?
Posté : 16 janv. 2017, 11:32
par germandrag
Ok
Your email please
Posté : 22 janv. 2017, 19:59
par Airspeed
Audjourd'ui j'ai measurer the cam in order to get valve timing correctement :)
Posté : 22 janv. 2017, 21:14
Nice! Did you got the results you were looking for?
Posté : 23 janv. 2017, 17:23
par Superflo
It's already a nice looking engine!
You timed the cam to the camcard specs or your own specs?
It took me a long time to get the geometry correct with these rockers and 15mm lift.
Posté : 23 janv. 2017, 21:42
par Airspeed
Superflo a écrit :It's already a nice looking engine!
Thanks!
Yes, for now I timed it to reflect the cam card as close as possible. I can always change something lateron if I don't like the powerband.
Oh? I had no problem with the valve geometry on these heads and the Pauter rockers: lift was exactly as it should be (15,68mm). With the roller tips its also less critical I think :wink:
Posté : 23 janv. 2017, 21:47
par Airspeed
Benoit a écrit :Nice! Did you got the results you were looking for?
Weirdly enough, I got a lot more duration because the valve opened avaragely 8 degrees sooner and closed 8 degrees later. Although the cam card says the values are measured with the Pauter 1,48 rockers, they seemed to be for less rocker ratio or.. they were meant for measuring at the cam, not the valve... Anyways, I set the timing so both valves measured the same (the 8 degrees) deviation. That was also just a touch from the center point of the slots in the adjustable cam gear, so that gave some added confidence :wink:
Cheers!
Posté : 23 janv. 2017, 22:09
I don't know a lot about engines, and reading that kind of post return me in class :thumb: :thumb:
Posté : 11 févr. 2017, 21:19
par Airspeed
Long block now finished :-D
:D
Posté : 11 févr. 2017, 21:51
par Superflo
Does your oil temp sensor see any oil with your dry sump?
Are you going to use an off the shelf exhaust or a home made?
Posté : 11 févr. 2017, 23:30
par Airspeed
Superflo a écrit :Does your oil temp sensor see any oil with your dry sump?
Yes,but that sensor is just for the analogie gauge. There is always some oil in the sump and the engine ecu uses another oil temp sensor which will be under in the head. I ran like that for years with the former engine(s) :wink:
That is part you see in the pic is of an off-the shelf exhaust (from VWSpeedshop.uk.co his system 9 version). Needs a little modification here and there probably. I haven't test fitted the rest of the exhaust yet.
Posté : 14 févr. 2017, 22:31
par Airspeed
Posté : 14 févr. 2017, 23:21
par germandrag
Posté : 15 févr. 2017, 00:26
par ElPax
Yes very good :thumb:
Posté : 21 févr. 2017, 12:16
par Airspeed
white lady a écrit :
Airspeed a écrit :Orratech system not installed yet on my engine, so I have no personal experience...
Ok thanks you i Will probably order one of them orratech or riechter at the end of the year.
Pic especiallement pour toi :wink: :
