Re: 1303 'Versuchsfahrzeug'/Mythbuster
First 66mm cranck in the 11' ?
You broke your nose, you change your turbo... I like this way of mind
- Airspeed
- Moteur : 2,4 T4T
I hope so!Superflo a écrit :First 66mm crank in the 11' ?
@Benoit:
Le 'neuf' turbocharger a 50% plus de 'flow' au contrair de subaru IHI turbo!
Le base c'est un Garrett 3076R (ball-bearing) adapté de subaru flanges (Its a used 'Blouch Dominator 3.0R').
J'espere le cylindre aluminium c'est plus de forte..(strong enough)
- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
Neuf turbo installé:
- Airspeed
- Moteur : 2,4 T4T
Alors, le resultat de turbo neuf: 350 ch !
Torque max.: 420 Nm.
http://www.youtube.com/watch?v=nljeNyH07Cs
Power at the rear wheels (appr. 300 ch):
Flywheel hp and torque:
TurboR
What the difference between black and pink mark ? what setting have you change?
- Airspeed
- Moteur : 2,4 T4T
I adjusted the fuel somewhat, but in the wrong direction... Didn't do much good. Was way too rich between 3250 and 4750 rpm (about lambda 0,75 at worse). Up top rpm it gave 10 more hp however.TurboR a écrit :What the difference between black and pink mark ? what setting have you change?
Besides the difference in the lines, how do you like the results for an aircooled track driven street bug with stock (type 4) crank, stock head castings and alu cylinders 103mm?
Congrats!
You must feel the big difference between the 2 turbos!
What's the next step?
congratulation Walter !
350hp !!!
next step : 400hp ??
350hp !!!
Very impressive !
TurboR
now you know you can enrich high rpm, and lean mid-rpm.Airspeed a écrit :I adjusted the fuel somewhat, but in the wrong direction... Didn't do much good. Was way too rich between 3250 and 4750 rpm (about lambda 0,75 at worse). Up top rpm it gave 10 more hp however.TurboR a écrit :What the difference between black and pink mark ? what setting have you change?
you proove that a T4 can do with few mods!
now you can do a vid with race taxi to see the différences between beetles and combis
hello airspeed,
Bon comme tu nous oublis je met a jour pour toi
http://www.youtube.com/watch?v=Hb_wzgslrLw
Changement de frein arrière, du maitre cylindre etc etc dis nous en plus
faire une platine c'est simple, on met l'étrier, on branche et met en pression on place l'ensemble et ya plus qu'a prendre les cote
- Airspeed
- Moteur : 2,4 T4T
Ah, m'excuse Alex de je t'oublie
Qui, le maitre cylindre de frein c'est changer de EMPI (qui, 'made in China'...) 20.6/20.6mm avec flange de 1303!
J'espere 'handling' should improve the most prochain saison
- Airspeed
- Moteur : 2,4 T4T
Test fitting the Heigo rollcage:
Someone/thing (virus?) had corrupted the links...as they did show up before...have repaired links now.
Modifié en dernier par Airspeed le 14 janv. 2010, 15:39, modifié 1 fois.
