Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
TurboR a écrit :yeah borg Warner, the best commercial turbo for now !!!
good choice!
which model did you choose?
The EFR for sure is, I totally agree! :thumb:
TurboR
Message par TurboR »
:shock: :shock:
you are aiming for 500+ hp?
Airspeed
Moteur : 2,4 T4T
TurboR a écrit ::shock: :shock:
Qui.
mais non maintenant :wink:
TurboR
small trick:
Oui = yes
Qui = who ;)
I need to follow this, and maybe when you plan a trip to the nurburgring tell us, i'm there sometimes (4 to 10 times a year :lol: )
+ DE 500 HP but max speed 220 KM/h
toujours d'actualité?
Airspeed
Moteur : 2,4 T4T
Alex a écrit :+ DE 500 HP but max speed 220 KM/h
Je ne comprend 'toujours d'actualité?' 'its always the current situation?
Max speed is not really about hp anymore above 400hp or so, but more about vehicle stablity: reducing lift and straight line suspension lay-out.
and big balls :roll:
Airspeed
Moteur : 2,4 T4T
TurboR a écrit :small trick:
Oui = yes
Qui = who ;)
Ah! that explains the reaction of mademoiselle :lol:
Will do! I love the Ring! :thumb:
PatFlat4Ever
Message par PatFlat4Ever »
I guess you know what exhaust pipes connect on the twin scroll turbo for maximum power ?
Airspeed
Moteur : 2,4 T4T
PatFlat4Ever a écrit :I guess you know what exhaust pipes connect on the twin scroll turbo for maximum power ?
Not exactly sure what you mean, but I am a real believer in equal length header with correctly paired cylinders: 1/3 and 2/4 :wink:
PatFlat4Ever
Yes for the paired cylinders. :thumb:
Airspeed
Moteur : 2,4 T4T
Wrapped the exhaust parts very close to the case and/or cylinderheads:
Airspeed
Moteur : 2,4 T4T
PatFlat4Ever
Where is the turbo ? For an another engine ?
Airspeed
Moteur : 2,4 T4T
PatFlat4Ever a écrit :Where is the turbo ? For an another engine ?
First N/A dyno result, then turbo will be added :wink:
PatFlat4Ever
So the compression ratio is already settled for turbo or you'll have to change it ?
