Re: 1303 'Versuchsfahrzeug'
very impressive, i love your bug :thumb:
Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
Superflo a écrit :Congratulations for the nice results!
Will you race it at EBI2?
Naturellement! :D
What cluth setup and flywheel bolts are you running ?
Stock (old too) porsche 915 225mm clutch and pressureplate and Ahnendorp HD 'ream to fit' 12.9 flywheel bolts.
Tnx Ayrton!
Airspeed
Moteur : 2,4 T4T
In front of the house before leaving for the dyno appointment:
Made a video of the dynorun. No smoke, no oil, just a piece of rag blowing away from under the car at the end :D
http://www.youtube.com/watch?v=Bhff2feNaRw
Airspeed
Moteur : 2,4 T4T
Naturellement! :D
I managed a 13,23 seconds @ 103,6 mph (167 km/u) which is my personal best so far!
The new pistons for the 2,2 ltr have arrived:
very nice parts
david
Message par david »
nothing else to say, great car, great look, and great work Mister Airspeed... :thumb:
what's the weight and size of your new pistons stock and with axle and link pin's on..?
Modifié en dernier par david le 26 juil. 2008, 13:17, modifié 1 fois.
JLC
Message par JLC »
Very nice car...I like it...
I found in my computer a photo of your car during EBI, here it is
Airspeed
Moteur : 2,4 T4T
Thanks for the picture Jean-Louis! Very much appreciated! :cheers:
David, thanks; actually I only took the pic while I was at the machining company, so I haven't got the parts at home yet. When they do get here, I'll weigh them for for with and without piston pin and rings :wink:
Airspeed
Moteur : 2,4 T4T
Cette weekend je remplacement ...the original rockers by (used) Pauter 1:1,48 rockers:
It runs even harder now and I have boost pressure much sooner :mrgreen:
I plan to make it to Bugshow 'a samedi' (on saturday). Will try to run in the 12's then :boire:
Airspeed
Moteur : 2,4 T4T
Ne pas succes: il etait un '11'er' temp :mrgreen: :mrgreen:
Le vitesse ne pas correctement.
Les autre run de 14.6 ne pas moi, mais il a un vitesse ne pas correctement aussi. Les vitesses sont minus appr. 20 km/h malheur.
Le deuxieme run 'my shifter broke'... :(
Very pity that the 0-60ft times and 1/8 times were not recorded...
guynocox91
Message par guynocox91 »
just a little "hello" at 1303 versuchssfahrzeug, thank you for your welcoming for the bugshow :wink:
Airspeed
Moteur : 2,4 T4T
Ah qui, je reconnais; It was very nice nice meeting you :D
Airspeed
Moteur : 2,4 T4T
Le meme engine de LeBugshow 11.99 run: encore 2.0 originale Type 4 ´ne pas possible de turbo´ :mrgreen:
270 ch, 345 Nm ±
New run on the dyno:
235 RWHP = 270 FWHP (grafh shows 266.8 :wink: ) @ 6000rpm and not descending...
345 Nm @ 4700 rpm
Stock crank, stock rods, stock pistons/cylinders, stock heads/valves
Scat single springs, Ti retainers, Pauter rockers.
In comparison to lasts run with the worn cylinders and stock rockers:
8) :thumb:
Airspeed
Moteur : 2,4 T4T
Le turbo @ le circuit de Zandvoort, Pays-bas. Il pleut avant, alors un peu de 'lentement' :P
Trackday on a wet track
