1200 "Autobahn-Renner" [NL]
- Aart-Jan
Finally some news. Haven't had much time to spend on the car, but did some small things,..
Exhaust is modified to fit between the big wheels and sidepanels.
Modified the automatic-starter nosecone to enable the gear to go further into the 914-transmission and let it rotate the flywheel nicely.
Mounted the front hood and doors.
That's it!
AJ
That's it!
AJ
- germanbuilder
- Aart-Jan
Re: 1200 "Autobahn-Renner" [NL]
I think that you built your car just like you take your pictures :
Just one error : you don't have a big porsche disc braking system
PERFECT !
what are the tyre size ??? and wheels ?
Benoît
Benoît
- Aart-Jan
Merci!
Front: 7" with 195/45/17
Rear: 8.5" with 215/45/17
Stock fenders!
Not yet... I must say, stopping distance even with stock discs and drums is really short, but that is because of the sticky tires. Many fast brakings in short time will generate too much heat-energy for these brakes though...Benoit a écrit :Just one error : you don't have a big porsche disc braking system
Porsche Boxster S wheels / Goodyear Eagle F1 tirescoxy-ben a écrit :what are the tyre size ??? and wheels ?
Stock fenders!
- fullpower
- Votre German : 1300 german
- Moteur : t4 2366
very nice
good feeling
congratulation
good feeling
congratulation
- Aart-Jan
Some more detailed pictures for the people who like it:
Sparco-stuff:
Steeringwheel mounted:
Stock 1600 for the moment. Will be converted to MegaSquirt later this year:
Also mounted a 1303 blower:
Sparco-stuff:
- fullpower
- Moteur : t4 2366
nice, i love sparco stuff
what 1303 blower
what 1303 blower
fullpower a écrit :nice, i love sparco stuff
what 1303 blower
ventilateur.
- dangerous
MS V1 or V2
- Aart-Jan
MS-1 V2.2 Extra. So, ignition will also be controlled by MegaSquirt, using an EDIS module.
Little detail. The Sub-D 9-pin connector you see below the switches is the place where I can plugin the laptop or MegaView LED-display. There is already a permanent cable running from the dashboard to the MS-ECU in the left 'battery-compartment'.
Utilisateurs parcourant ce forum : Bing [Bot], Semrush [Bot] et 12 invités
