Airspeed
Moteur : 2,4 T4T
Re: 1303 Mythbuster -> 2,2 ltr T4Turbo version 2.0
Message par Airspeed »
PatFlat4Ever a écrit :So the compression ratio is already settled for turbo or you'll have to change it ?
No changing of compression ratio anymore, c'est ca! :wink:
Airspeed
Moteur : 2,4 T4T
Some new tires (drag radials from M &H) for drag racing:
and finally finished the case breathing system with nice AN10 lines:
Airspeed
Moteur : 2,4 T4T
Un petit amélioration de suspension avant :wink:
Cést un partie de MBT, allemagne.
Nice part and a triangle is born. :D
For the big braking it's perfect.
Airspeed
Moteur : 2,4 T4T
After the N/A dynotime (189 Cv a 7300 RPM), I've started building the turbo header:
cheap speed
Moteur : projet 1620 turbo
Message par cheap speed »
marvelous!!!!!!!!!!!!!!!!!!!!!!
What's your piping diameter?
Airspeed
Moteur : 2,4 T4T
Inner diameter = 39mm
Outer diameter = 42mm (1,5mm wall thickness)
For turbo and fast spool, I would have liked it even a little bit smaller (38mm inner), but this size was more readily available..
Lots of people go too big on diameter with turbo. Its not neccesary and only gives slower spool-up.
bill77
Message par bill77 »
What's new on your project since last year ?
Il y a de la vie par ici !
There's life here !
bill77
Mais oui !
Il y a même un sacré paquet de canassons par là !!! :shock: :-D
Heureux pour lui que le projet prenne vie !
Pas mal du tout
coool
Mais in the inside video, le mur est vraiment proche!! faut pas se louper
