A small video would be great
- JLC
- Moteur : T4 2056cc
- Airspeed
- Moteur : 2,4 T4T
Drag-race jante pour le'occasion: 3,5Jx17 avec 105/95 radial pneus :twisted: : 9,6kg ensemble!
Modifié en dernier par Airspeed le 10 juin 2008, 22:35, modifié 1 fois.
- Airspeed
- Moteur : 2,4 T4T
Assemble le turbo appendages
Many more ducts and pipes will follow, but the intercooler is at least in place now:
- Airspeed
- Moteur : 2,4 T4T
Oui, thats the ideaSuperflo a écrit :It'll see a lot of air flow!
The sides of the intercooler will be covered by the cut-up duck-tail.
Yes, but it will hang just behind cylinder no.1The turbo will be attached directl at the end of the BAS header?
If its more finally installed with all pipework, I'll make another pic that will show how it all works
Ah, got you fooled with that one huh? Its actually a dry-sump set-up, with the oil tank and oil cooler at the front of the bug. You may just see the blue coupling behind the header which is the suction side of the oil pump.No oil cooler?
Greets,
Walter
- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
Re: 1303 'Versuchsfahrzeug'
Le turbo installé:
Downpipe:
Downpipe:
now I love the ricchiert fan...
- germanbuilder
- fullpower
- Votre German : 1300 german
- Moteur : t4 2366
y'a vraiment du lourd là
I love it
I love it
- JLC
Whouahou
Crazy projest
so nice
Crazy projest
- kevin
- Votre German : Cab 1303
Hi Walter,
Congratulation for you engine!!! Great job! I hope it will give you a lot of happiness
Please shoot a picture of your Saco slave cylinder... the way you instaled it.
Thanks a lot!
Kevin
Thanks a lot!
Kevin
- Airspeed
- Moteur : 2,4 T4T
Merci beaucoup for the nice responses!
Kevin, I spoke to a friend of yours today on the Budel meeting! Sorry, c'est tres difficile to make a good picture that really shows what had to be done for installing the Saco slave cylinder. Its mostly custom mounting and fabrication. This one is the best I could find I already had:
Last evening and today at Budel. Turbo pressure only 0.5 Bar and 168 Cv et 244 Nm
The meeting with the mobile rolling road:
Le result:
Le result:
- germanbuilder
