Re: 1303 'Versuchsfahrzeug'
with what, do you cleanned your bloc ? With my dremel, i don't obtain this result.
- Airspeed
- Moteur : 2,4 T4T
To be honest, the machine shop has a big dishwasher for auto parts and that gave this result
:twisted:
- Airspeed
- Moteur : 2,4 T4T
Hehe, smart Alex
Yes, I made some progress:
Au milieu, c'est le piston dans le moteur:
How much power do you expect from the new engine?
- Airspeed
- Moteur : 2,4 T4T
Well, the stock 2 liter 914 engine with just ratio rockers had 270 hp at 1,0 bar boost, so I expect the new engine to have at least 300 hp. As off that point the OEM subaru turbo will probably max out somewhere, so we'll seeSuperflo a écrit :How much power do you expect from the new engine?
- Airspeed
- Moteur : 2,4 T4T
Changez les injectors 500cc pour Siemens 660cc:
love your JENVEY throttle bodies...
- bill77
Any news ? Is the engine barking yet ?
- Airspeed
- Moteur : 2,4 T4T
Ah, qui, very much sobill77 a écrit :Any news ? Is the engine barking yet ?
http://www.youtube.com/watch?v=FvEH8Z6STWM
up close:
http://www.youtube.com/watch?v=Rg4p2WMqoHs
She ran 12.3 's with the 18" wheels and street tires and a 12.18 in the 1/4 mile with slicks and a slipping clutch.
Very happy with that!
- bill77
Wouaouh !
Now we want more ! Any pics of the finished engine ?
When do you dyno it ?
You did a great work anyway !
- Airspeed
- Moteur : 2,4 T4T
Tnx, I did dyno it on a mobile dyno the other day, but the conditions were not ideal and results were a bit diappointing: the were about the same as with the 2 ltr engine.
http://www.youtube.com/watch?v=kOYaWh5hFSk
Dynorun itself:
http://www.youtube.com/watch?v=xSoyPv_QhNo
Flywheel power/torque graph at 14,5 psi or 1.0 bar boost:
I have since then tuned the engine a bit more and also made a little better intake. In two weeks time (june 21) the engine will be at that same mobile dyno again, so I hope my tuning made a difference.
Dynorun itself:
- Airspeed
- Moteur : 2,4 T4T
The finished 2,2 looks pretty much like the former 2 ltr when all is in the car:bill77 a écrit : Any pics of the finished engine ?
That is how it was dyno'd. It now has the bigger K&N filter again and I made the air intake tubing the same size as the turbo inlet (which is 2,25" or 57mm. Intake tubing was 2" or 50mm and is now 60mm)
- bill77
Torque 350 Nm ! That would suit me very very well !
Now I understand better the way it revs up in last gear !
Keep up the good work !
