1200 "Autobahn-Renner" [NL]
Re: 1200 "Autobahn-Renner" [NL]
1955cc turbo engine in the works...
benicox
Message par benicox »
La configuration ???
Aart-Jan
Message par Aart-Jan »
76 x 90.5mm (=1955cc)
5.5" CB Super Race Rods
Webcam 218 avec 112' Lobe Centers
Stock heads, ported and converted to twin plug
Mexico fuel injection intake manifold
Megasquirt ECU with JAW wideband and EDIS ignition
Stainless hideaway turbo header
TD04L-14T turbo (from Volvo S40/S60)
More pictures: http://www.keversite.nl/fotoalbum/my_photos.php?id=4568
Just preparing for some more fun at the Nurburgring next year!! :lol:
benicox
Aart-Jan a écrit : Stock heads, ported and converted to twin plug
Quel est vraiment l'intérêt du passage en double bougies par cylindres ?
Aart-Jan
By igniting the fuel mixture at two locations, the burntime will be shorter (giving less more needed timing advance). By shortening the burntime, not only efficiency increases but available time for detonation also decreases. So besides a more efficient combustion, a higher compression ratio or boost level can be used, giving again more efficiency and power! We will see how this turns out in practice...
dangerous
Message par dangerous »
tres bonne anallyse et moins de perte thermique car les temps de combustion est plus court
en voila un qui va pleinement exploiter sa MS :thumb:
you use two or four transistor for controling the two edis coil pack ?
Aart-Jan
At first I will try to use the stock EDIS controller and just wire two sets of coils to it. If that doesn't work properly, I will use four transistors for direct ignition control.
You are also using MS?
dangerous
yes
http://dangerous.skynetblogs.be/archive-month/2009-03#
http://dangerous.skynetblogs.be/archive-month/2009-05#
we put it in a bus with T1 1600 engine (fuel only)
we doesn't tune it but he run well :boire:
I must to take time for the spark :(
Aart-Jan a écrit :and just wire two sets of coils to it
Maybe it will divide the power of the spark, because you share it !
And if your coils hasn't the same impedance, maybe it will not be divided in 2... but a ratio due to it.
Aart-Jan a écrit :I will use four transistors for direct ignition control.
Much better I think !
Aart-Jan
No. The coils are permanently connected to +12V and are switched to ground by the EDIS controller. By connecting two EDIS coilpacks to one controller, both coilpacks will be switched to ground at the same time over the same pin. So, you drain more power throught the EDIS controller. The controller is only making the connection. I don't exactly know what is the limit of the internals (transistor) of the EDIS controller (too much power drain can fry the internal transistor), but it's worth the experiment IMHO.
Ok with you ! I've not understood this way at the first time.
I believed that you would connect 2 coils on 1 EDIS output...
the engine is ready ??
Benoît
Aart-Jan
I wish it was already finished. Unfortunately, I didn't have much spare time last months, so no further progress on the project.
Some old pictures of the latest progress:
Relocated wastegate actuator
VW TFSI chargecooler core
Hyundai H100 oilcooler
All oil lines received pressed couplings:
Utilisateurs parcourant ce forum : Baidu [Spider] et 5 invités
