Re: 1303 'Versuchsfahrzeug'/Mythbuster
Can't see the pics
Seems to have a problem with photobucket...
Walt, can you upload them again with this method : http://germanlook.org/viewtopic.php?f=23&t=1897
Thanks
Thanks
- Airspeed
- Moteur : 2,4 T4T
Just repaired the links. Tout est bien maintenant ?
TurboR
is it steel or alu rollcage?
Just too big, but great !Airspeed a écrit :Tout est bien maintenant ?
- Airspeed
- Moteur : 2,4 T4T
Merci benoit!
Its steel! Heavy too! Total weight: 35kg.
TurboR
Airspeed a écrit :Merci benoit!
- Airspeed
- Moteur : 2,4 T4T
More steel welded in..:
TurboR
probleme on the pics !!!
- Airspeed
- Moteur : 2,4 T4T
- SilverRS
very nice Walter, looks great!!
- Airspeed
- Moteur : 2,4 T4T
Tnx Dirk!
Forgot to post the dash pic:
et pour Florian
This will be the new left front seat:
and I hope these will arrive soon:
et pour Florian
ricola
I really like how close you got the cage to the A pillar and have kept the ducting. Will be interesting to hear how much the cage stiffens up the car on track!
Do you have to get those top mounts drilled/welded yourself? If so, it wouldn't have been much more work to make your own like I did!
- SilverRS
Walter, are those top mounts,from La performance?
- Airspeed
- Moteur : 2,4 T4T
Yes, they still need to get drilled/welded by me, but all the right parts to do so (and fit the damper) are there now. I can do some things myself or with a little help from an alu welder/machine shop, but cannot do everything myself like some of us über-gearheadsricola a écrit : Do you have to get those top mounts drilled/welded yourself? If so, it wouldn't have been much more work to make your own like I did!
Yes, the set comes from LAperformance Dirk.
