Airspeed
Moteur : 2,4 T4T
Re: 1303 'Versuchsfahrzeug'/Mythbuster -> 460 Ch.!
Message par Airspeed »
1208cc type 1 turbo EFI dans le assemblage 8)
Re: 1303 Mythbuster -> 1200cc T1T Challenger
Really nice. Can't wait to hear it sing!!
Airspeed
Moteur : 2,4 T4T
Motor finished and she has run! Yahoe!
Maintainant beaucoup de 'mapping'/tuning :wink:
just perfect, a beautiful horsepower factory :thumb:
jcoxforever
Message par jcoxforever »
really perfect ! very crazy ! :thumb:
how much power it developpe ?
kept silent made one essays for the bench power ?
hum ? :scratch: I'm going to resell my T4power :lol:
Airspeed
Moteur : 2,4 T4T
jcoxforever a écrit : how much power it developpe ?
Nothing yet, as it only runs since yesterday! :lol:
No, don't do that! T4 is much better for big street power.
I still have mine too and it will come back even better! :biggrin:
Airspeed
Moteur : 2,4 T4T
This weekend I disassembled the 2,2 T4 engine as I wanted to change the cam for this season.
Heads, Pistons, cylinders, bearings, crank, all looked great!
Pistons:
Unfortuneately, it turned out that one rod is bend! :( Look at the second rod from the left:
Anybody have a set of (used) Pauter rods for a 1,7ltr T4 crank I can take over? :roll:
I think you reached the stock rods limits!
Did you notice something when the engine was runing with the bend rod?
Airspeed
Moteur : 2,4 T4T
Superflo a écrit :I think you reached the stock rods limits!
I think it was because of boost-cut and heavy back-fires that caused this.
Stock rods can easily hold 500Nm, even more I think. Not big explosions from rpm limits and/or hard-cuts (fuel cut) on top of that.
Actually turned out 3 rods were bend...
No, not really. I had expected a little more power, so the piston not being straight in the bore must have been a problem, loosing some compression probably.
Fortunatly I found some Pauter rods as replacement :mrgreen:
:shock: ouch!!!!!!!!big pressure!!!
jcoxforever
i don't understand really,boost-cut and heavy back-fires, too much compression and those are the connecting rods wich made fusible :scratch:
you are really lucky in your misfortune ! you would have been able to explode your engine ?
and the brace had nothing ?
Airspeed
Moteur : 2,4 T4T
jcoxforever a écrit : you are really lucky in your misfortune ! you would have been able to explode your engine ?
Yes, very lucky probably. I am still amazed that the aluminium cylinders survived and look like nothing ever happened. Even the piston ring-gap is still the original size.
Qu'est-ce que c'est, un 'brace' ?
jcoxforever
oh ! excuse me , i want to say cranksafht ! :lol:
yes , it 's really a tough engine, the proof ! :wink:
Airspeed
Moteur : 2,4 T4T
Crankshaft is spotless and must be straight as all main and bearings were super nice as well:
I noticed this kind of "pitting" on my 2.4L engine, I assumed it was caused by harmonics due to a non-balanced trigger wheel, why do you think?
