Re: 1303 Mythbuster -> 1200cc T1T Challenger
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :thumb:
Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
diabolo a écrit ::shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :thumb:
Mais non, cette ici c'est :shock:
:lol: :lol: :lol:
I am making a table out of it, so don't worry, its not going into 'la coccinelle' :wink:
Airspeed
Moteur : 2,4 T4T
Premier run de 1200 turbo engine a wastegate boost (BOV leaking) a 6200 Rpm, maintenant avec FK7 et 1,4 rockers 8)
PSCHIIIIIIIIIIIIT !! :cheers:
incredible!!!!!! :thumb: :thumb:
Airspeed
Moteur : 2,4 T4T
Alors, le petit 1200 turbo manage 174 Ch a seulement 5500 Rpm en germany le 28. Avril 2012 'Bitchspeed pre-MKT party' :-D
Apres, le 2,2 T4T moteur re-build commence:
Central cooling system:
germandrag
Message par germandrag »
Very nice Walter :cheers:
bill77
Message par bill77 »
145 cv/litre, not bad at all, I'd say :cheers: ! ! ! :thumb:
Waooo Walter! One more time it's really impressive!!!
what's you're feeling with the 1.2T compare to the 2.2T
great anyway! :cheers:
Airspeed
Moteur : 2,4 T4T
Merci beaucoup! :D
que un 1200cc moteur avec un G50 Transmission n'est pas un combination tres bien (driving off from stand still) :lol:
:lol: Ok
low torque
and in the 1200cc categorie what was your position?
Airspeed
Moteur : 2,4 T4T
More very long first gear of G50 and indeed much lower torque down low because of an FK7 cam with 1.4 ratio rockers on a 1200cc engine.
Next turbo 1200 was 120 hp but at 0.8bar boost, so I won by quite a large distance :wink:
Unfortunately a lot of participants didn't finish in time and one n/a 1200 with duel 36 Dells, 324 schleicher and a stinger broke down just before.
Airspeed
Moteur : 2,4 T4T
1200 removed and working on the T4T to get it reassembled again:
It'll look great!!! you'll still have space for the intercooler with the vertical fan system or you planify to change?
and also I have a question that I want to ask you for a while... what is it from the engine that you'll use as a table?
curious to see the result also at the end!!!
fantastic anyway! :thumb:
