AUTOBAHN RACER
Re: AUTOBAHN RACER
:biggrin:
Re: AUTOBAHN RACER
Flange Instructions
The Flanges are made in the USA and as such are imperial
I.E. drilled for 3/8 UNF bolts.
All joints in the UK are metric 10mm.
Please run a 10mm clearance drill through the holes in the flanges prior to assembly.
Also do not use washers on the bolts – locktite them.
We use super glue and metal ties or lockwire to retain the boot on the flange.
Also please check driveshaft travel clearance prior to assembly with the flange bolted to the CV but without the boot. This allows you to observe driveshaft plunge.
If boots are superglued to flanges you will be unable to do this.
Avec ce genre de chose c'est encore un truc a se faire "chier"!!!!
Re: AUTOBAHN RACER
Ricola Pls give more details concerning this : (especially Also do not use washers on the bolts – locktite them.)
Flange Instructions
ricola
Re: AUTOBAHN RACER
Message par ricola »
Not a big deal but I didn't see that text before I fitted mine. One needed the holes drilling with a 10mm drill, the other one did not. I didn't use any washers or loctite, just a good torque.. They are quite thick machined parts..
The flange for the rubber boot is on the large side so a bit tricky to get the original boots stretched on, the aftermarket silicone boots are probably much easier to fit.
Re: AUTOBAHN RACER
ok thks for your answer
kombyman25
Re: AUTOBAHN RACER
Message par kombyman25 »
Le KG est en reportage sur le VW Mag de ce mois-ci !!
toujours aussi beau ....
Vipergrun
Votre German : 1303 1975
Moteur : 2 l T4
Re: AUTOBAHN RACER
Message par Vipergrun »
Alex a écrit :
KamperRS a écrit :A quand un bel article dans SuperVW mag pour que l'on aie des explications techniques sur ce chouette montage ? :lol: :lol: :lol:
Cela m'a été proposé par l'intermédiaire d'un tropical man mais pour certaine raison que je n'evoquerait pas en public :biggrin: cela ne se fera surement pas
Alors ............................ :biggrin: :biggrin: :biggrin:
Re: AUTOBAHN RACER
regarde qui est l'auteur des photos et tu vas comprendre ;-)
Re: AUTOBAHN RACER
va falloir que je l achete alors
Re: AUTOBAHN RACER
Je viens de l'acheter!
Dommage que ces nazes ai fait une faute d'orthographe... germannlook avec deux "n" bordel !!!
Sinon la caisse est toujours aussi belle :thumb:
Re: AUTOBAHN RACER
tham a écrit :va falloir que je l achete alors
M....e moi aussi, ca doit bien faire 4-5 ans que je ne le lis plus.
Grace à Alex les ventes de super vw vont exploser ce mois ci :lol:
Re: AUTOBAHN RACER
Benoit a écrit :Je viens de l'acheter!
A la fin de l'article ya pas de faute hihih
Re: AUTOBAHN RACER
pour ceux qui veulent juste voir vite fais
http://www.journaux.fr/super-vw-magazin ... 84444.html
cliquer feuilleter et ecrire page 70 :wink:
Re: AUTOBAHN RACER
bel article :thumb:
Re: AUTOBAHN RACER
j en ai acheter quelques uns au debut,mais plus apres,ici je l ai lu direct dans mon shop de pieces vw qui vends aussi les revues,c est cool d avoir un project francais dans un livre francais :biggrin:
felicitation a notre vieille ours du forum :biggrin: :biggrin:
Utilisateurs parcourant ce forum : Majestic-12 [Bot] et 4 invités
