VWRX 1303 cab
Re: VWRX 1303 cab
New screens background :wink: 8)
Re: VWRX 1303 cab
ca test par ici :wink:
Re: VWRX 1303 cab
ricola
Re: VWRX 1303 cab
Message par ricola »
You are beating me to updating my own thread Alex! :lol: I'll do a proper update once it's finished...
Re: VWRX 1303 cab
Looks good!!! Cannot wait to see it done!!!
Good job! :thumb:
ricola
Re: VWRX 1303 cab
It is all done now and works great, I was worried it would be too harsh now the front end is all rose jointed but steering is much better (and lighter) and you can feel the suspension working much better. Very happy with how it turned out! I'll post some more pictures later...
Re: VWRX 1303 cab
Great évolution!!! Nice!
Re: VWRX 1303 cab
Great news! :thumb:
Were did you get those rose joints?
I am very concerned about the quality everytime I see some for sale on the web...
I you have a good address please let me know :wink:
ricola
Re: VWRX 1303 cab
I got them from: www.mcgillmotorsport.com I got the medium quality ones which were well up to the job from the ratings...
The inner ones are M10 so that are a direct fit and maintain the camber adjustment for fine tuning, the forward ones are M14 as they are in single shear and are as big as I wanted to go..
Re: VWRX 1303 cab
Alright! Thanks
Great job anyway! :rambo:
ricola
Re: VWRX 1303 cab
Here's the whole lot with captions...
Time for a mini project! A while back during the MOT test I was slightly concerned with how much the wheels moved about when the tester spread the front axle on the pads. Having seen a few designs of A arms at Spa and online on the boxergasse forum I've decided to give it a go myself! I wanted to do it as a completely bolt on swap. Part of this change is to de-couple the stock anti-roll bar from the geometry so this will be spaced down underneath the A arm. I've seen people put it above but my radiator is in the way and I have plenty of ground clearance.
The inner spherical joint will be M10 and the forward tension link section will be M14, I will also be using sealed boots to keep them weather tight. At the spindle I'm using the original design ball joint. Some people re-position the lower axis as they run very low.
Before I took the stock suspension off, I put the car on stands and with the steering dead ahead and a vertical level marked up the position to the floor. This is obviously just to get the geometry about right, I can fine tune it afterwards.
The key part to the swap is creating a forward bracket, this aluminium block spaces the anti-roll bar downwards with the stock saddle clamp and gives plenty of meat to mount the forward joint.
The block fitted, not how it is fitted to the chassis form. My mate, Seb, machined up some tube end fittings for it.
The first lateral link tacked together
and fitted to the car, now to align the hub and measure up for the tension link. The last bit will be to work out how to connect the anti-roll bar.
Tension link tacked in at nominal geometry position. Some people will fit a clevis type joint to the lateral part but I only wanted minimal adjustment. Welded will give better stiffness.
I trawled ebay for a nice short anti-roll bar that I thought I could adapt and ended up with this from a Mk2 Ford Mondeo, less than £5 delivered for the pair! It was a case of making up some fairly simple adapters to bolt on to the standard 1303 anti-roll bar ends.
Brackets to weld on to the new A arms
Finished A arm ready for paint
Finished 'kit' ready to be fitted! Note I did machine down the blocks some more compared to earlier pictures to maintain the stock pick up position heights and maximise ground clearance.
Ball joint pressed in and rod ends adjusted with their rubber boots to give them a bit more life
All done!
Closer view of one side..
So, the verdict: in summary well worth it! The front end feels so much more alive and communicative but NVH is hardly affected at all. The tyres seem to work a lot better as they are not moving around so much and the steering is even a bit lighter too. Even on motorways you can feel what's going on with the most subtle of movements. Overall it just gives so much more confidence in what the car i doing and that means a lot!
For anybody else that wants to try something similar this is what I used:
Inner joints: M10 male rod ends with high misalignment spacers
Forward joints: M14 rod ends with standard misalignment spacer, additional 18mm spacer inboard
Stock lower strut ball joints
1 1/2" diameter 0.1" wall thickness CDS tubing
Mk 2 Ford Mondeo/Cougar rear anti-roll bar links
If you can't work out the rest then frankly you probably shouldn't be trying to copy it!!
Re: VWRX 1303 cab
:boire:
Nice job !! Now, no flexibility !! Braking and turns they must be awesome ?
ricola
Re: VWRX 1303 cab
Yes, definitely much nicer to drive, I'm enjoying corners much more now!
Re: VWRX 1303 cab
Good idea to improve the front end and nice work, I like the joint boots and the use of stock lower strut ball joints, perfect for a street car.
ricola a écrit : Some people will fit a clevis type joint to the lateral part but I only wanted minimal adjustment.
I'm one of those, I think that a clevis type joint would be better, I'm a little concerned with the weld cracking.
Something like this:
ricola
Re: VWRX 1303 cab
That would almost be a 996 front end... I'm not worried at all about the weld cracking, it is a big joint and I prefer that extra stiffness over a clevis, I don't really need the adjustment.
Utilisateurs parcourant ce forum : Majestic-12 [Bot] et 3 invités
