Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
Superflo a écrit : Do you map the engine with RPM vs TPS and add pressure compensations when bolting the turbo stuff on?
But its never that simple: for turbo I really need to replace the injectors (now 450cc, which I still had, to my old 1000cc injectors), so the injector map will have to be tuned all over again. But basically you are correct.
Clutch will also have to be replaced (I now use a lighter clutch) by then.
But I still need to get it running first; for now, still waiting for a few parts (oil routing connections...)
TurboR
Message par TurboR »
why map this in RPM/TPS in turbo? :scratch:
even in N/A in some case it's easier to map in RPM/MAP !
RPM/TPS is easier with indivudual throttle bodies and an agressive cam on a N/A engine. With the DTA ECU you can enable pressure compensations for fuel and spark when installing the turbo.
TurboR
yes that's right, i forgot the "individual throttle bodies" thing :lol:
Airspeed
Moteur : 2,4 T4T
Superflo a écrit :RPM/TPS is easier with indivudual throttle bodies and an agressive cam on a N/A engine. With the DTA ECU you can enable pressure compensations for fuel and spark when installing the turbo.
Also my experience ^^
Cam is not really that aggressive though, just about 266 duration @ 0.050"lift iirc :wink:
Airspeed
Moteur : 2,4 T4T
New package arrived today:
:mrgreen: :mrgreen: :mrgreen:
TurboR
New hairdryer? :lol:
:lol:
Airspeed
Moteur : 2,4 T4T
TurboR a écrit :New hairdryer? :lol:
Ohhh yeah! 8) 8)
Did you get only a box or is there a turbo inside? :-D
PatFlat4Ever
Message par PatFlat4Ever »
Twin scroll ?
Airspeed
Moteur : 2,4 T4T
PatFlat4Ever a écrit :Twin scroll ?
Qui!
What a sexy tiny thing :rambo:
Miam… :cheers:
TurboR
yeah borg Warner, the best commercial turbo for now !!!
good choice!
whish model do you chose?
