No changing of compression ratio anymore, c'est ca!PatFlat4Ever a écrit :So the compression ratio is already settled for turbo or you'll have to change it ?
- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
Some new tires (drag radials from M &H) for drag racing:
and finally finished the case breathing system with nice AN10 lines:
- Airspeed
- Moteur : 2,4 T4T
Un petit amélioration de suspension avant
Cést un partie de MBT, allemagne.
Nice part and a triangle is born.
For the big braking it's perfect.
- Airspeed
- Moteur : 2,4 T4T
After the N/A dynotime (189 Cv a 7300 RPM), I've started building the turbo header:
cheap speed
- Moteur : projet 1620 turbo
marvelous!!!!!!!!!!!!!!!!!!!!!!
What's your piping diameter?
- Airspeed
- Moteur : 2,4 T4T
Inner diameter = 39mm
Outer diameter = 42mm (1,5mm wall thickness)
For turbo and fast spool, I would have liked it even a little bit smaller (38mm inner), but this size was more readily available..
Lots of people go too big on diameter with turbo. Its not neccesary and only gives slower spool-up.
- bill77
What's new on your project since last year ?
Il y a de la vie par ici !
There's life here !
There's life here !
- bill77
Mais oui !
Il y a même un sacré paquet de canassons par là !!!
Heureux pour lui que le projet prenne vie !
Pas mal du tout
coool
Mais in the inside video, le mur est vraiment proche!! faut pas se louper
