bill77
Message par bill77 »
Must be quite satisfactory !!! Congrats !
Big grin on your face ?
After all the hard work and deep thinking ...
Airspeed
Moteur : 2,4 T4T
Re: 1303 Mythbuster -> 2,4 ltr T4Turbo en construction
Message par Airspeed »
Thanks for keeping the thread alive mon amis!
A moment je suis constructer noveau moteur: 102mm Deutz x 74mm = 2,4 ltr 8)
JPM camshaft.
Alors peut etre encore plus de CV..?
Greetings,
Walter
bill77
415 was not enough ? :biggrin:
Airspeed
Moteur : 2,4 T4T
bill77 a écrit : ↑23 janv. 2020, 03:25 415 was not enough ? :biggrin:
Its not of course :mrgreen: and the engine would have made 500 easy, if it wasn’t for a building mistake (switched pistons) of me that resulted in engine damage...
So I had to rebuild it again.
bill77
Bad luck !
But that's what winters are for, rebuilding the new beast that will dump everybody out there next spring !!! :rambo:
The vw aircooled that run and the most powerful to my knowledge.
The subaru engine are aircooled...
Airspeed
Moteur : 2,4 T4T
Almost ready to be installed:
I'll try to run it N/A first, so I have a baseline again and because I want to try a new (patented) idea on the exhaust :wink:
Keep the pictures coming :thumb:
:thumb: :thumb: :thumb:
Nice engine :thumb:
:P :P :P :P :P :P :P
kevin
Votre German : Cab 1303
Message par kevin »
Nice job Walter, congratulation :thumb:
Did you cut the Deutz cylinder under clamping load similar to an installation on the engine?
While cutting mine to bore size of 105mm I measured a deformation of 0.03 to 0.04mm with the 4x 35Nm torque which represents a significant part of the operating clearance. Therefore I machined my cylinders under pre-load as they recover 100% shape (elastic deformation)
Did you by any chance measure how they behave with a 102mm bore diameter?
Airspeed
Moteur : 2,4 T4T
kevin a écrit : ↑07 avr. 2020, 08:53 Nice job Walter, congratulation :thumb:
I understand and you did good practice with that! :thumb:
These were however new german cylinders (not the china copies) and were already 102mm to start with. So, I didn't bore them and machinework for shortening was done elsewhere. They are extremely thick and sturdy (very good hard iron), so making them shorter only won't distord anything.
Airspeed
Moteur : 2,4 T4T
Superflo a écrit : ↑06 avr. 2020, 20:33 Keep the pictures coming :thumb:
Ok :wink:
Repaired the damaged head:
Crank assembly goes back in with same bearings and all:
With the Deutz cylinders, I wanted some extra cooling.
This is for a little lower engine bay temps:
and this for some extra oil cooling reserve:
Top one is my old cooler I had in there for over 15 years or so...
Bottom one is Mercedes as well (from ebay :lol: ) but obviously just bigger thus better and fits just behind the front valance grill!
Airspeed
Moteur : 2,4 T4T
Apres N/A assembler exhaust with anti-reversion chambers:
Utilisateurs parcourant ce forum : Semrush [Bot] et 6 invités
