- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
Fitting the floor plates of the CB pressure hats gave a 'small' problem:
Lets just say that hole doesn't help keeping pressure within...
Also a 'made in china' 'bell-mouth' downpipe arrived. Boy, are those cheap! If they are value for money remains to be seen, but it fits and look very good. I only needed the first part, so I hope this stainless is weldable with mig...
- Airspeed
- Moteur : 2,4 T4T
New spacers for the throttle bodies have been made:
Painted the Riechert shroud orange again (it was black, noir). I also bought an up-pipe from a subaru and a new stainless 3" muffler from Borla:
At the moment the 914 2 liter stock engine will be used to fit everything and so I can drive a little sooner:
- germanbuilder
- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
Well, you may be correct, but I really wouldn't know untill I have tried it. Besides, not all subaru turbo's are the same
Thanks for your comment tho!
Because of the CB linkage carb tops, I needed to position the fuel rails on the outside again
No fit, so I have bought a 90-degree 1/4NPT to a D-06 to try to fit tomorrow...
- Airspeed
- Moteur : 2,4 T4T
- Airspeed
- Moteur : 2,4 T4T
[/img]
