Page 2 sur 7
Re: VWRX 1303 cab
Posté : 22 mars 2009, 23:23
ricola a écrit :I am also considering remaking the framehorns
Just like origin or a new idea?
Re: VWRX 1303 cab
Posté : 22 mars 2009, 23:26
par Airspeed
Cool to see another G50 install
Welcome Richard
Re: VWRX 1303 cab
Posté : 22 mars 2009, 23:40
par ricola
At the moment I'm thinking something along the lines of the sketch below, made out of 40x60mm tube, that way I can make them suitable for the subaru engine mounts. I am making the new floor perimeter from the same tube so will tie it all in together, I think it will be nice and strong when I'm finished.
Wally, did you get reverse working properly in the end? I'm planning to keep the reverse switch so won't have the problems you did. It should be exposed between the two tubes of the new framehorns.
Rich
PS more pics of the swap are on my website...
Re: VWRX 1303 cab
Posté : 23 mars 2009, 11:45
par Airspeed
Hi Rich,
Yes, reverse was found again and works fine and light now
It turned out to be a stuck spring loaded ball in the internal gate shifter and/or a clearence issue with the linkage (not entirely sure as I worked on both at the same time).
Anyways, the reverse switch had noting to do with the reverse engagement/operation as such.
Bracing looks logical. Just a pity the subaru engine install made all this cutting and subsequent reconstruction work neccesary... (you know where its coming from
Re: VWRX 1303 cab
Posté : 05 avr. 2009, 21:36
par ricola
Well good progress this weekend!
New brackets for the 911 front mount:
Getting the shape for the top of the new framehorns
No going back now!
The splines remade to fit further out inside the torsion tube, I'm using shorter swing axle torsion bars now
All welded in!
More progress during the next week or so, a full 4 days next weekend!
Re: VWRX 1303 cab
Posté : 22 oct. 2009, 23:57
par ricola
Been a while, it's now back on 4 (new) wheels!
Specs: Cayman fitment, 19" x 8,5J with 235/35R19 front tyres
19" x 10J with 265/30R19 rear tyres
Rear wings will need to be widened by about 45mm..
Ground clearance is really good!
8" to sill strengtheners and 6" to engine sump at ride height, I still have 4" ground clearance to the sump when on the bumpstops...
Re: VWRX 1303 cab
Posté : 23 oct. 2009, 06:56
par mric
What a works!
Very impressive... nice job!
Re: VWRX 1303 cab
Posté : 07 janv. 2010, 21:51
par ricola
Re: VWRX 1303 cab
Posté : 07 janv. 2010, 23:59
par Airspeed
You just MADE your own new floors?
Wow! Truely awesome work!
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 01:27
par ricola
I bought a beadroller, great toy!
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 03:47
par tintin13_2
What an awesome work !
i'm fan
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 09:47
par Alex
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 11:51
par prototix
superbe boulot
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 22:39
par jief31
very interresting modification and very nice work.
i like your choice for the wheels.
did you find the color for the final painting.
please continue to put the pictures to follow the project.
Re: VWRX 1303 cab
Posté : 08 janv. 2010, 23:40
par ricola
I will not be changing the colour, it is very rare and has grown on me a lot since I bought the car. Believe it or not it is called Schwartz metallic! I have only ever seen one other bug in this colour...
