Trouve: Riechert/Willibald Moteur
Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
[img:800:600]http://www.keversite.nl/fotoalbum/fotos/61056.jpg[/img]
[img:800:600]http://www.keversite.nl/fotoalbum/fotos/61081.jpg[/img]
HWT c'est: Heinz Willibald Tuning, mais je n'est sais pas du tout cette moteur... (Cv?)
marc1302
Votre German : 1302
Moteur : typ 4 2256
Message par marc1302 »
Hallo
Generell hat einen T4 2.0 von Willibald 100 PS…
Tschüss
Marc
:wink:
david
Message par david »
difficult to say, the willy balt system "eat" a lot of power thru the angles power pulley and the flat fan...
the belt blend 4 times... I strongly dislike it !! :evil: :evil:
Airspeed
Moteur : 2,4 T4T
Benoit a écrit :the belt blend 4 times... I strongly dislike it !! :evil: :evil:
Pourquois? Have you ever used one yourself? or is it from hear-say you don't like it?
FWIW, in return for a few extra hp, it cools MUCH more evenly your cylinderheads. I like that part :D
By the way: Bernd Rummenholl has this cooling system on his Gelb-Schwarze Renner 1303 avec 2,6 Type 4 moteur (sans turbo).
Il marche toujours 11.8 seconds dans le 1/4 mile avec le belt connected ! You dislike that too? :roll:
It's just due to the mechanical constraints on the belt...
I'm not sure that a belt is build to bear this twists... :roll:
david
Message par david »
I've got a flat fan conversion it absorbes 15hp were a vertical fan and belt takes only 5 or 6hp compare to a dynotest without any belt on.
it's good looking, I like it, but the belt doesn't last long, and over 5800rpm of on a fast quick shifting gear change, the belt "fly's away"... :rambo:
Airspeed
Moteur : 2,4 T4T
david a écrit :I've got a flat fan conversion it absorbes 15hp were a vertical fan and belt takes only 5 or 6hp compare to a dynotest without any belt on.
'a' flat fan conversion? There is only one 'offical' one... :roll:
My vertical (Bas) fan conversion absorbed 15 hp at 6000 rpm, also measured at a dyno. Can show you the print-out...
