Airspeed
Moteur : 2,4 T4T
Re: 1303 Mythbuster -> 2,2 ltr T4Turbo version 2.0
Messagepar Airspeed » 27 févr. 2017, 22:52
Do you map the engine with RPM vs TPS and add pressure compensations when bolting the turbo stuff on?
But its never that simple: for turbo I really need to replace the injectors (now 450cc, which I still had, to my old 1000cc injectors), so the injector map will have to be tuned all over again. But basically you are correct.
Clutch will also have to be replaced (I now use a lighter clutch) by then.
But I still need to get it running first; for now, still waiting for a few parts (oil routing connections...)
TurboR
Messagepar TurboR » 28 févr. 2017, 12:15
why map this in RPM/TPS in turbo? :scratch:
even in N/A in some case it's easier to map in RPM/MAP !
Messagepar Superflo » 28 févr. 2017, 13:08
RPM/TPS is easier with indivudual throttle bodies and an agressive cam on a N/A engine. With the DTA ECU you can enable pressure compensations for fuel and spark when installing the turbo.
TurboR
Messagepar TurboR » 28 févr. 2017, 15:22
yes that's right, i forgot the "individual throttle bodies" thing :lol:
Airspeed
Moteur : 2,4 T4T
Messagepar Airspeed » 28 févr. 2017, 21:55
Also my experience ^^
Cam is not really that aggressive though, just about 266 duration @ 0.050"lift iirc :wink:
Airspeed
Moteur : 2,4 T4T
Messagepar Airspeed » 01 mars 2017, 17:53
New package arrived today:
:mrgreen: :mrgreen: :mrgreen:
TurboR
Messagepar TurboR » 01 mars 2017, 18:26
New hairdryer? :lol:
Messagepar Benoit » 01 mars 2017, 19:29
:lol:
Airspeed
Moteur : 2,4 T4T
Messagepar Airspeed » 01 mars 2017, 20:23
Ohhh yeah! 8) 8)
Messagepar Superflo » 01 mars 2017, 20:46
Did you get only a box or is there a turbo inside? :-D
PatFlat4Ever
Messagepar PatFlat4Ever » 01 mars 2017, 20:59
Twin scroll ?
Airspeed
Moteur : 2,4 T4T
Messagepar Airspeed » 01 mars 2017, 21:46
Twin scroll ?
Qui!
Messagepar Benoit » 02 mars 2017, 00:32
What a sexy tiny thing :rambo:
Messagepar StraBenrennen » 02 mars 2017, 09:39
Miam… :cheers:
TurboR
Messagepar TurboR » 02 mars 2017, 11:41
yeah borg Warner, the best commercial turbo for now !!!
good choice!
whish model do you chose?
Retourner vers « Vos projets »
Utilisateurs parcourant ce forum : Aucun utilisateur enregistré et 20 invités
