Re: 1303 'Versuchsfahrzeug'/Mythbuster -> 403 Ch.!
That is cool!
Can you tell us more about this engine, or it is your tiny secret?
TurboR
Message par TurboR »
i think counterweighted crank, big turbo, cams, heads .... forged pistons but hard to found
i think 200hp is possible with some works. or more maybe :evil: :mrgreen:
Airspeed
Moteur : 2,4 T4T
Message par Airspeed »
TurboR a écrit :i think counterweighted crank, big turbo, cams, heads .... forged pistons but hard to found
I agree, that is what shoud be done, but that is even more $$. The 1200 is supposed to be 'fun on the side' :-D
Instead it will be original crank, rods, pistons and heads. But I will try to upgrade the original parts a bit like I did in my current 2.2 type 4 8) Plus a suby stock 2L Impreza wrx turbo (too big) of course :mrgreen:
I also agree that 200 hp should be possible, but that will take much more effort...
The cam and the turbo will have to do all the work...
May take some time as even a type 1 with mostly stock parts is not cheap if you want to keep it alive a little bit longer :wink:
Downsizing guys, downsizing ! :cheers:
Airspeed
Moteur : 2,4 T4T
Made some nice progress this weekend:
Trial fitting the too big of a turbo.
Looks like it might even sort-of fit :D Be aware that I have a bit more room there as my engine is moved a few cm further backards.
The 4" (!..) air inlet will however collide with the Cup strebe so will need to make s/th for that, for which I already have an idea :)
:shock:
kev1 a écrit ::shock:
+1 !! :shock: :shock:
Airspeed
Moteur : 2,4 T4T
:lol:
This is what happened first:
TurboR
twin scroll :mrgreen: the good way to boost early with a big turbo :cheers: :cheers:
this is not for 1.2L :lol:
Airspeed
Moteur : 2,4 T4T
TurboR a écrit :twin scroll :mrgreen: the good way to boost early with a big turbo :cheers: :cheers:
++++++++ :cheers: :thumb:
Airspeed
Moteur : 2,4 T4T
Changer the springs to CB650:
Is it the valve spring removal tool avaible at CSP?
Airspeed
Moteur : 2,4 T4T
Superflo a écrit :Is it the valve spring removal tool avaible at CSP?
Yes! However...I have had some trouble with the keeping the arm centered as it does not sit stable on my Ti retainers.... hence the 2 hose clamps.... :?
TurboR
You put springs from a honda cb 650 ?
NiToOoOo
Votre German : 1200 de 1974
Message par NiToOoOo »
TurboR a écrit :You put springs from a honda cb 650 ?
I think it's rather this... :wink:
http://cbperformance.com/catalog.asp?ProductID=1586
Utilisateurs parcourant ce forum : Baidu [Spider] et 2 invités
