Re: 1303 'Versuchsfahrzeug'/Mythbuster -> 403 Ch.!
That is cool!
Can you tell us more about this engine, or it is your tiny secret?
TurboR
i think counterweighted crank, big turbo, cams, heads .... forged pistons but hard to found
i think 200hp is possible with some works. or more maybe
- Airspeed
- Moteur : 2,4 T4T
I agree, that is what shoud be done, but that is even more $$. The 1200 is supposed to be 'fun on the side'TurboR a écrit :i think counterweighted crank, big turbo, cams, heads .... forged pistons but hard to found
i think 200hp is possible with some works. or more maybe![]()
Instead it will be original crank, rods, pistons and heads. But I will try to upgrade the original parts a bit like I did in my current 2.2 type 4
I also agree that 200 hp should be possible, but that will take much more effort...
The cam and the turbo will have to do all the work...
May take some time as even a type 1 with mostly stock parts is not cheap if you want to keep it alive a little bit longer
Downsizing guys, downsizing !
- Airspeed
- Moteur : 2,4 T4T
Made some nice progress this weekend:
Trial fitting the too big of a turbo.
Looks like it might even sort-of fit
Be aware that I have a bit more room there as my engine is moved a few cm further backards.
The 4" (!..) air inlet will however collide with the Cup strebe so will need to make s/th for that, for which I already have an idea
kev1 a écrit :
+1 !!
- Airspeed
- Moteur : 2,4 T4T
This is what happened first:
TurboR
twin scroll
the good way to boost early with a big turbo
this is not for 1.2L
- Airspeed
- Moteur : 2,4 T4T
++++++++TurboR a écrit :twin scrollthe good way to boost early with a big turbo
- Airspeed
- Moteur : 2,4 T4T
Changer the springs to CB650:
Is it the valve spring removal tool avaible at CSP?
- Airspeed
- Moteur : 2,4 T4T
Yes! However...I have had some trouble with the keeping the arm centered as it does not sit stable on my Ti retainers.... hence the 2 hose clamps....Superflo a écrit :Is it the valve spring removal tool avaible at CSP?
TurboR
You put springs from a honda cb 650 ?
- NiToOoOo
- Votre German : 1200 de 1974
I think it's rather this...TurboR a écrit :You put springs from a honda cb 650 ?
http://cbperformance.com/catalog.asp?ProductID=1586
