Airspeed
Messages : 324 Enregistré le : 21 oct. 2007, 22:34
Votre German : '75 1303 sunroof
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 12 mai 2012, 19:08
Alan GL a écrit : It'll look great!!! you'll still have space for the intercooler with the vertical fan system or you planify to change?
I think yes, not a problem as the fan is on the front of the engine
and also I have a question that I want to ask you for a while... what is it from the engine that you'll use as a table?
You mean the engine stand?
Its a bell-housing from a T2 bolted to a plate with a shaft to rotate the engine and all is bolted to the workbench/table.
Messages : 819 Enregistré le : 02 oct. 2007, 23:08
Votre German : 1302 de 71
Moteur : type4 2,4L
Message
par Alan GL » 12 mai 2012, 19:27
No no no I mean the engine that you'll use to do a table (furniture) the kind of W8 ??? I would like to know from what it comes...
Airspeed
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 12 mai 2012, 19:37
Alan GL a écrit : No no no I mean the engine that you'll use to do a table (furniture) the kind of W8 ??? I would like to know from what it comes...
Ah,yes!
I really look forward to dismantle that engine further. Its from a VW Passat model 3BG (last Passats that had the engine longitudinal mounted, 2000-2003-ish). Its a W8 4.0 ltr engine and very compact. Shame the rods/rodbearings are the weak point and spares are difficult to get. This one has fialed rod bearings too by the feel of one of the pistons...
Moteur : type4 2,4L
Message
par Alan GL » 12 mai 2012, 19:53
That's cool! put photo when it's finished!!!
and the T4T also of course!!!!!
good luck
Airspeed
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 24 mai 2012, 19:05
Just finished the cooling shroud for the long block and awaiting the lightened flywheel this weekend.
First had to cut it in 3 parts to shorten it (engine is very small/short):
Moteur : 2806cc T4 EFI
Message
par Superflo » 24 mai 2012, 19:19
What kind of clutch setup are you going to use on the type4 engine?
Airspeed
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 24 mai 2012, 19:47
Its will be a Tilton cera-metallic dual disk set-up in 7,25" diameter (184mm).
I'll make a pic when clutch and flywheel are back here. It should be very light-weight too (both flywheel and clutch)
Cooling shroud is 'repaired'
Airspeed
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 24 mai 2012, 20:01
Recent article in a general Tuning magazine de pays-bas:
and the new smaller turbo arrived pour chassee Race Taxi au Spa cette annee
'Petit' neuf a gauche et le grande au droit:
Messages : 4235 Enregistré le : 20 avr. 2008, 15:39
Votre German : BUS 1971
Moteur : 2457cc
Contact :
Message
par tham » 24 mai 2012, 20:02
pchiiiiiiiiiiiiiiiiitttttttttttt
Messages : 3609 Enregistré le : 20 sept. 2007, 23:01
Contact :
Message
par Alex » 16 juin 2012, 12:44
Moteur : type4 2,4L
Message
par Alan GL » 16 juin 2012, 12:57
Airspeed
Moteur : 2,4 T4T
Contact :
Message
par Airspeed » 16 juin 2012, 18:00
Merci Alex!
The b*tch finally started today after a faulty VR-sensor had me fooled for most of the day. Gas respons is much faster and I needed to add about 8% more fuel in the map
Contact :
Message
par Alex » 16 juin 2012, 18:10
Messages : 1510 Enregistré le : 22 avr. 2010, 15:02
Votre German : 1302 1970 en mutation
Moteur : ej 25 turbal
Message
par diabolo » 16 juin 2012, 19:46
1200 bodybuilding, extrem!!! i like it!
Moteur : type4 2,4L
Message
par Alan GL » 16 juin 2012, 19:55
Nan la il est repassé en 2.2T T4
version 2.0 comme il dit
Utilisateurs parcourant ce forum : Bing [Bot] et 6 invités
