Airspeed
Moteur : 2,4 T4T
Re: 1303 Mythbuster -> 1200cc T1T Challenger
Message par Airspeed »
Alan GL a écrit :It'll look great!!! you'll still have space for the intercooler with the vertical fan system or you planify to change?
I think yes, not a problem as the fan is on the front of the engine :wink:
and also I have a question that I want to ask you for a while... what is it from the engine that you'll use as a table?
You mean the engine stand?
Its a bell-housing from a T2 bolted to a plate with a shaft to rotate the engine and all is bolted to the workbench/table.
No no no I mean the engine that you'll use to do a table (furniture) the kind of W8 ??? I would like to know from what it comes...
Airspeed
Moteur : 2,4 T4T
Alan GL a écrit :No no no I mean the engine that you'll use to do a table (furniture) the kind of W8 ??? I would like to know from what it comes...
Ah,yes! :-D
I really look forward to dismantle that engine further. Its from a VW Passat model 3BG (last Passats that had the engine longitudinal mounted, 2000-2003-ish). Its a W8 4.0 ltr engine and very compact. Shame the rods/rodbearings are the weak point and spares are difficult to get. This one has fialed rod bearings too by the feel of one of the pistons...
That's cool! put photo when it's finished!!!
and the T4T also of course!!!!! :biggrin: :cheers:
good luck :wink:
Airspeed
Moteur : 2,4 T4T
Just finished the cooling shroud for the long block and awaiting the lightened flywheel this weekend.
First had to cut it in 3 parts to shorten it (engine is very small/short):
What kind of clutch setup are you going to use on the type4 engine?
Airspeed
Moteur : 2,4 T4T
Its will be a Tilton cera-metallic dual disk set-up in 7,25" diameter (184mm).
I'll make a pic when clutch and flywheel are back here. It should be very light-weight too (both flywheel and clutch) :wink:
Cooling shroud is 'repaired' :lol:
Airspeed
Moteur : 2,4 T4T
Recent article in a general Tuning magazine de pays-bas:
and the new smaller turbo arrived pour chassee Race Taxi au Spa cette annee :biggrin:
'Petit' neuf a gauche et le grande au droit:
pchiiiiiiiiiiiiiiiiitttttttttttt :biggrin:
:shock: :shock: :shock: :shock: :shock:
:boire:
Airspeed
Moteur : 2,4 T4T
Merci Alex! :wink:
The b*tch finally started today after a faulty VR-sensor had me fooled for most of the day. Gas respons is much faster and I needed to add about 8% more fuel in the map 8)
:shock: 1200 bodybuilding, extrem!!! i like it!
Nan la il est repassé en 2.2T T4 :wink: version 2.0 comme il dit :biggrin:
